but UK living expenses so spensive
thats why you live up north mate. 2 dollars a pint, houses are about 90k aud. jobs pay about 35k aud and everyone is nice, cos you have the same thing in common. you hate southerners.
*disclaimer
prices are relative to me leaving in 08/09.... may or may not be higher now.
*disclaimer
Sounds like my kind of living. What sort of land do you get for 90K?
Hnnnnnng that garage tho
http://www.realestate.com.au/property-apartment-vic-clayton-118326151
What you think Alex? might check it out.. I was looking more closer to the city but get shit all or something really old for your money the closer you get :\ Also this is across the road from Coles which is nice..
Edited by UNR33L
Looks ok man but suss out the body corp situation it can be high in those developments for bs things
bitch of a location IMO. level crossing causes traffic to bank up and no one in clayton can park or drive very well.
that, plus if they decide to get rid of the level crossing... thats traffic woes and construction for 6+ months
Also, theres 2 coles there. both stock the same shit and its not very diverse. i used to drive the extra 5mins to safeway on warrigal rd.
It's right across the road from Coles, that is the reason alone you should go 'shut up and take my money' mode.
And no, you won't see me covered in blood there.
wow 81sq including garage, I've stayed in hotel rooms bigger..
thus why I'm looking out of town.
I thought the 81sq was excluding the garage.. they usually do exclude the parking / storage in apartments I thought? if it's included then that's pretty bad and not worth looking at then lol.
Edited by UNR33L
Apart from a little traffic / possibly noise (would need to have a look) I kind of liked the location, near heaps of shops and the station would make it pretty easy to get into the city, walk across the road, grab a BBQ chicken dinner done.. :D
Inb4 walking across the busy road, get hit by car & ambo doesn't save me cos' shit wage
Edited by UNR33L
Clayton aye. Suburb across from me :thumbsup:
Also inb4 Korean girlfriend
from line under diagram seem to be included.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
