Good upgrade Adam, even with the popped motor it'll surely be faster than your gtst
lol
First modification will be to get rid of those god awful LMs and replace with D1Rs
gooby plz
So with all the GTR hate going on, it might be timely to post up yesterday's purchase
grats fag
  • Like 1
What type of security guards does in come with?
dude it's a 33... not the holy grail 34.... ONLY 34's need security guards.
33's only need a facebook and instagram account (which may be a problem for birds)
  • Like 1
Niice, however the engine rebuild & full Rwc with vicroads inspection will be fun :/
Yep gonna be a bit of work and dollars, but so much money saved on mods. Final build price *should* arrive on par with buying a standard one, but will be something forged and ballistic.
Loving the colour too, not a huge fan of midnight purple etc.
  • Like 1
Plans for the engine?
Stock transplant? Full rebuild? power goals?
Nek minnit racepace $15k rebuild
Still deciding, it will really depend what comes up. If a built 26 pops up, I'll consider that for a cheap and risky way out. Otherwise, budget may allow for RacePace to rape my wallet.
Was making 340awkw with the HKS turbos before engine issues (it's actually still quite driveable and the engine idles smoothly besides the sound, so don't know how far gone it is), which sounds plenty for me in a street car. I'd like to put it on sugar cane for response, though.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
