Leaning towards a standard one for half the price. 600hp is a fair whack of power, but I assume that's at the engine, in which case the turbos and current tune are already putting that out on 98...and I'd like to go ethanol. Revving that other one to over 9000 would be ridiculous
There's just something so spastically awesome sounding about a 3 litre twin turbo all wheel drive on ethanol, before I've even heard the exhaust note
This may have just gone from a possibility into a must do
  • Like 1
Ad doesn't say sold. Hence my curiosity.
After he comes along to a meet
And shows us his girlfriend
how about you come over to my house and be my wife boy.
seriously
hamish.
mums gone OS.
i can only cook and eat so much bolognaise, steak, salad and veggies.
give me nice soup recipe, or chicken roast. k go
seriously
hamish.
mums gone OS.
Eggs fgt
why 9000? its like saying pushing your turbo to 40psi. its a nice number but unnecessary if setup properly (for street and occasional track use)
congrats hamish. when you getting torago?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
