who the f**k said too much power? power was the same to within 5kw between our cars, his was all in by like 2000 RPM doe...
people underestimate just how much extra displacement that 0.5l is... it's 20%
For me I'll be simulating my litre motorbike, which just had oodles of power everywhere, but most importantly in the low and mid range where big bore short stroke engines usually suffer
And for that matter it's pretty much the same discussion as 600s versus 1000s - they both fast as each other when they are on song and most people can ride a 600 better than they can ride a 1000. But on the road, in traffic, in higher gears, that low end torque is blissfully awesome!
I'd also rather be able to boost in 4th and 5th at cruising RPMs
But yeah we'll see
An interesting dyno graph it will make
Old mate from facey pm'd me about that forged RB26...it's a brand new rebuild with receipts...could be tempted if it saves me a few grand on the RIPS VL. Will see what's wrong with current RB first.
Just put 20w/50 oil in and she'll be right.
receipts for the $350 pistons... great...
  • Like 1
anewwotm8?
Tell Chris to check his emails!
Previous owner has had it running with the knocking, you've driven it with the knocking. High chance that the crank can't be salvaged. Sure, it could be... but theres definitely better odds that it won't be!
  • Like 1
Guess I'm hoping for the chance it's something in the valve train like a bent valve or something.
Will also give a chance to suss out anything else I need to acquire, like a new head for example.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
