yeah ive never been to any, figured the crowd / trying to get a drink and waiting ages would just be stupid and a lot of $$$
Ding ding ding
You only forgot the massive queues to the most disgusting portable toilets you could imagine
You lot just need to suck it up and eat some more pingaz
+1
everyone having a sook & forgetting the point;
Paying for a concert for each individual international band/artist will cost a lot more than 1 festival & most artists wouldn't host their own concert as they cant justify the costs.
If your taste in music is your aussie indi scene, then wait for a pub concert in some hipster suburb else festivals are good bang for buck when wanting to see a whole line-up of international artists.
Unfortunately I miss out on all festivals due to my roster :(
a project leader i worked with in QLD was a jetski nut.
was useless at his job, lived on gold coast, maori background (born in NZ), had 2 jetskis, no kids, late 30's and worked 2-on 2-off
#definitionofFIFO #whycantdecentpeoplegetjobs
  • Like 1
And you fgts call me the VWL hipster
youre the grand daddy hipster hamish.
all hipsters have a small picture of you in their cardboard wallets and on their walls.
they love you, they cherish you, they pray to you.
nice one
Ive retained my Platinum for another year & half way to getting a complementary Gold membership for a friend.
Dammit I said I'd buy that membership from you
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
