I bought a pair.
He only has them available in 265/35/18... which is what I run on the rear....
Now, to burn through the remaining 90% of my current set and then I can use the new ones ;)
Hell, I paid $1200 for 3 (1 x 235 + 2 x 265 + (1 free tyre)) when they had their last nationwide sale...
2 x 265's for $440 is a bargain :D
And no... definately not trying to be a richo. I don't have any of those skills.
Sorry I just remembered they don't come for 8-10 days. If you pay me on Wednesday I'll pay for a pair for you.
Was thinking the same thing... going to be 2 streets away on Saturday, so was going to pick them up then... wait a second...
anyone a member of the buy/sell/swap pages?
some guy put up an add offering to suck cock while his mrs finger bangs him.
i print screened it.
dont know if i should post in lulz thread..
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
