Out of 300 people, only one couple gave me a non cash present. It was a photo frame..... uwotm8
I bet out of the 300 people you'll remember the photoframe couple the most lol
People invite way too many f**king people to weddings is the problem, they're self indulgent bullshit at its finest.
They are the selfie of events.
Too expensive to invite heaps of people, close family and friends will be enough for me
This!
  • Like 3
We used the engagement party as a way to weed out ppl
As we did it at Amy folks home we could invite lots and stlill keep it chea
If ppl did not rsvp or worse rsvp they were coming and then not turn up with out contacting they were off the wedding invite list
Got numbers down so quick was great
  • Like 4
Pop Quiz:
Tony - What did I get you for your wedding gift?
Everyone Else - What should I have gotten him that would have been the most perfect present ever and made Lynnie hate me for life?
Ric gonna be remembered for a long time and that vase will shine up instead of being spent on a holiday or the next iPhone.
Hopefully! Will check if it's visible in their home when they invite me around for dinner
Pop Quiz:
is the answer a stripper?
Birds, I need to hire you for breakfast dem eggs looked maaad.
also, dat vl @ 1 min, & 5:45 running an easy 9 moh you needa get one - 800hp min
Edited by UNR33L
Yeh I agree but is what it is, gifts are fine but getting shit u don't want blows for all we know rics vase is an annoyance they have to keep and pull out in the event he comes over.
cash has been the norm for certain cultures for ages
not with the brakes planning
with 295's?
it all good going to have some fun with the car this year.
start lining up some parts to fix the cosmetic issues and make go faster at same time.
good time to be alive.
I got 275 on 10.5" under there, and that was with a fairly wide offset (+22) I flared the guards enough to easily get 295 under there. If you want to be safe, get a higher offset. If I remember correctly there was plenty of strut clearance
what you running front?
that's my big concern, rear I ahve to do something wild anyhow as the guard is fked
front I have some options...
I had 9.5" +12
I can't remember the tyre size though. Fronts had heaps of room. My offsets were too low, should've gone a little higher.
Hollandaise or the deconstructed with bacon bits and garlic bread?
I demand further clarification regarding this hollandaise of which you speak.
Didst thou purchase said hollandaise from ye olde supermarket like a common peasant or didst thou appease thine hollandaise gods and maketh same?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
