Why hasn't anyone made a flash tuner type setup for the skylines? flash to 98, flash to e85 tune or what ever..? or is this out there and I just don't know?
ECU design too old. And apparently can't crack through case in point, R33 ecus - both gtst and gtr so I'm told.
Thats what i did with PFC + datalogit
Just carried both maps and swapped according to fuel.
It's a2 min job including starting laptop
  • Like 1
As above, fk flex fuel
I commit to one or the other. I'm not afraid of commitment.
Feel my shirt...you know what material it's made from?
Boyfriend material.
I think I'll stick to pure E85 for the skyline... Chris said he can do an emergancy 98 tune on the PowerFC by adjusting the maps linked to a different AFM setting... so I could just switch from the Z32 preset with my powerful E85 tune, to some other one in there which has been modifed to be a safe as anything 98 tune.
Just takes more time on the dyno to tune around the unswitchable variables, but would mean I could fill up with 98 on my way home from the track and switch it on the hand controller to have it run well enough that I can drive it home... obviously not red lining full boost, but enough to get me back to Melbourne from Winton...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
