Dude, he's right of Genghis Khan.
The only reason he supports liberal is because National Socialist Party isn't possible.
The funny thing is while I sit a little to the left on some issues, I am a swinging voter. Hell i voted for howard at one point.
You only think I'm left because the centre is sooooo far away from where you sit.
I think your left cos you are. I see your shared articles & comments couldn't be more blinkered.
Bolt a socialist? Not even close
Abbott may indeed be a monumental flog but it's the party not the person. Shorten is as useless as tits on a bull has labor proposed even one policy since the election?
Edited by alr33x
Just because I don't like the current federal government doesnt mean I must therefore be some die hard labor supporter.
I know all you see is Right and "the enemy" but there is actually a lot more to it than that believe it or not.
My honest position is that a centre right government that is willing to take its time to achieve outcomes rather than being ultra conservative and trying to do it all in 3 years for no purpose other than re-election is what this country needs. It is also what the LNP or ALP could turn into if the right team is put into play.
ALP will never be centre right they can't help but spend money, people think the country's stuffed cos of libs but gladly ignore the fact it's stuffed cos Krudd went on a spending spree and didn't create fk all jobs. Maybe extra firemen to solve the insulation batts disaster..
  • Like 1
Domestic sparky (at the cheaper end of the scale) $70 call out + $70 an hour.
Construction EBA, ~$44 an hour with a few other allowances.
Bloody unions extorting the poor, poor builders and destroying the country.
Masseuse, $60 an hour minimum, does 50 minutes of actual work in that hour.
PT $60 an hour minimum, does an 8 week course to be a fitness expert.
I wonder how many PT's and massage therapists died at work last year.
I wonder how many of the companies they work for cut corners to save a buck while putting their lives at risk.
I wonder how dangerous their workplace is on a daily basis.
Sorry i missed this.
I was taking the piss...
National socialism differs from traditional socialism in that it is generally accepted to be far far right. The most prominent example of course being Nazism.
Don't expect to see any real policy from Labor for another 12 months. They don't need it right now while Abbott is the LNP's worst enemy. All they do is risk an unpopular policy while they are surging further and further ahead. Will be interesting to see if they learnt anything from Keatings loss here.
If Abbott goes and Turnbull comes in you will see the policies come out of nowhere.
Yeh I vote liberal regardless of the leader we are discussing the wider voter base..to get broader appeal they need to change
Don't worry Dezz we know you will vote for whoever the militant Union tells you to.
speaking of moving, anyone want my old fridge? its old but works fine. been using it for almost almost 3 years. its free, but if you want delivery i would probably need a hand. would be a good beer/spirits fridge/freezer.
I'll take it assuming you're in the west or north? Unless it's already taxed.
I'll vote for the cock suckers that are going to f**k me the least.
You'll just vote liberal regardless.....
funnily enough if you earn what I assume you do your probably better off with a liberal gov too but I'd be pretty confident you don't vote for them
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
