So there are these videos on YouTube of peoole opening kinder surprises that are held inside larger colourful balls, like a babushka (sp?) Doll setup. Its just a closeup of the hands with bad music... kids LOVE them.
Orlando is currently sitting with my work laptop completely enthralled by this shit.
There are thousands.
Aparently the inventor is minted now :0
Yeh the Disney toys or whatever - minted to the tune of $5 million! Was on radio the other day.
i laugh at the violent protests undertaken by uni students the other day/week.
"bunch of people hurt and a blind woman has been hit in the face" or something. she probably either a) got swept up by uni people, tried to get help from police and was mistaken for arrogant youth or b) got clipped by a bicycle and a journalist included her in the casualty list.
but seriously, lets make university affordable and drain the government so more people can sit on youth allowance and then not be able to get a job afterwards because the world needs more Environmental Scientists and law clerks.
it should be for people who work hard or pay their way. not little Annie who took a gap year after high school to travel to greece on some inheritance money, do 2 years of arts before discovering herself and then studying social science part-time for 4 years.
Japan has similar issues. bringing in foreigners to do the work that no locals want to do, and the skilled workers (mostly men) dont like foreigners (brazilians, latins) working for their company. And the emphasis on straight-A schooling over there, where the women often exceed in schooling, study, get a job and once married then become homemakers.
  • Like 1
There's a wheels on the bus nursery rhymes video on YouTube with 350 million views
54 minutes long
Obviously parents trying to put their kids to sleep
But someone is rich
It'll be -$20/h with interest if Al gets his way :P
-$30/h once you factor in the cost of beer at the uni bar between lectures.
Yeah... that ain't work... It's not work unless you're sneakily browsing facebook, VWL and redtube
  • Like 3
that kind reminds me of something.......
:whistling:
uni =/= work
Uni = uni
Also, it's very obvious what background people have when they type like this :P
=/= means accounting background
!= or <> means computing / programming background
"what the hell does that mean" means farming background
  • Like 1
I am at work right now then.
(actually at work... for the government)
The problem with most governments, Australian, American, and most others is this:
People don't try and govern for a better country a decade after their term is complete.
That's the issue.
People don't vote for the best country in 2035.
People don't make policies for the best country in 2035.
If people voted and made policy for the long term, we'd be living in a better country, both now (because people in 1995 would have thought about it), and in 2035.
  • Like 2
That video i posted is the problem with politics.
There is no way i could ever be a politician. It woildnt matter what side of the fence i sat on there would be video's ans photo's of my past that would destroy me.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
