Yeah I've got two new O2 sensors. Car has always been a pig to drive until it got to about 1/5th on the water temp gauge then all of a sudden it goes into a different map and drives as if its come onto boost. Did it on standard ecu and now Nistune. So I'm a little concerned it might be the very expensive ignitor as most other things have been changed. Still makes a lot of power though :\ Realistically haven't got much different fuel economy from Tuned E85 to stock ECU on 98/100. So somethings definitely causing fuel to get raped in the first 5 minutes of driving more than it should..
Edit: To clarify I'm managing about 250kms daily driving, probably could get more but I'm not keen on finding out how fast the last bit of E85 disappears. This seems pretty low to me considering I don't thrash it at all.
Coolant temp sensor all good? What temperature range plugs are you running? Stock coils?
Well I got a second hand one with the car when I bought it so I'm gonna assume he changed it for a new one (coolant temp sensor).
New BKR6E gapped to .08
Splitfire coilpacks
New coilpack loom
AFMs just changed for another set
O2s new
Racepace use BKR plugs over BCPR or that your choice?
You might be right, truth be told it was just what came off the top of my head. Now I'm not sure which one. Regardless though whichever one it is its worked on countless cars so it SHOULD be fine in mine, it's the right plug for RB and E85 anyway..
Yeah just did some looking up on that and you're right. Shouldn't be the problem really and I'm pretty sure its BKR6E that we use not BCPR6E.
Looks like I'm going to have to just keep throwing parts at it, hard one to diagnose on the dyno as you have to leave it on overnight, check it in the morning on a cold engine and you have to know what sensors SHOULD be doing what at what temperature, and hope that you notice one of them change suddenly and more drastically. Even though all the other ones will change at the same time too.
can go past dat 3rd gear overtake move @ 80
It is good and that's what I do with my rolling drags, dropping to 3rd at 80 is actually my favourite move! Closely followed by 2nd at 50 when approaching lights and they turn from red to green...
lol my friend used to drop to second at 80
You're gonna hate -9s on a 2.6 then! Had some kid try to be hektik in his stock GTST giving those little pulls next to me today at 80kmh. I geared down to 3rd and put the foot down, I basically just coasted away making small amounts of boost, it wasn't very impressive I must admit. That's with -7s as well!
they both work, it's just the BCP have a ~2mm longer electrode and contact slightly better
BKR wouldn't cause the issues, I was just curious
For this reason I use BCP...my coilpack springs are a bit short and I had random non firing cylinder issues
How much power you running?
May have to swap for -5s, but I love response and will take it over outright power any day
Also winning is winning haha
Speaking of, very easily dispatched of an Evo 8 off the line today...where he really should have got me...instead he got bogged down off the line and if that happens it's all over for a 2 litre turbo AWD
Do crashes necessitate a write off or can be a minor incident?
Thefts:
Ric
Borci
Birds
Tony
Alvin
Crashes:
Hamish's m8
Do bikes count? had 2 stolen :(
Forgot I wrote off a 33 when I was 18 as well lol.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
