Hmmm that one can sometimes take the input shaft with it, hopefully not yet and it's just on it's way out.
Outside chance, but can also be a clutch issue. Thrust bearing another slight possibility if it's rattling around on the input shaft retainer because it's slightly touching the pressure plate (a good way to test out this one is to put a small amount of pressure on the clutch pedal so that it presses the bearing firmly up against clutch, but doesn't engage the clutch...if noise disappears then it's probably this. Otherwise input shaft / spigot bearing is your culprit.
Might as well do rear main while you're there too.
Any IT gurus here can point me to a cheap/free webhosting service?
Just need a service with cPanel so I can setup a catchall email forwarder.
cheers
I've used crazy domains in the past, seemed decent.
Stop being irrational
Ordinally, I'd intercept here with an acute pun/expression derived from mathematics, but my obtuse, two-dimensional humour oddly does not appeal to the lowest common denominator, only outliers like Ric and even yourself...plus I don't want to be mean and ruin the mode, so I'll be a square and stay out of this 1. But I regress.
  • Like 2
We're very proud to make you a member of our very select group. Welcome to Super Friends.
Welcome, Super Friend, I am called Ham, because I enjoy ham radio.
Missus dad hired skip. filled it up to level on sunday.
Wake up monday morning and theres a shit load of crap on top + bathtub and hot water system.
What the f**k.
What did you expect...skip belongs to the neighborhood between 7pm and 7am
  • Like 1
If it means me waiting more time to get in cause your car gets priority...hell no
Nah mine will take at least 6 months we're predicting as customers will always take priority no matter how late they walk in the door through my build :P So I'm currently in the process of buying a daily for the long haul. Theres 3 engines being built in the engine room atm, all of them RPM 2.8s. I was merlin when I walked in and saw 3 new crankshafts all just sitting there..
*ahem* engineer whose specialisation is statistics checking in & you reference the lawyer
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
