It's ok to be judged within reason..
But riced up car no thanks
If I was still in sales, I'd rather no judgement from them until I had sussed them out and then I could talk about my other car etc. if I saw that they might be into that.
But yeah riced up cars do you no favours unless you work in that industry or for Autobarn.
Saw a real estate agent rock up in a riced-up rx8 :/
Lol when we had our Track Day tech night the other month the pizza delivery dude rocks up in an RX8 with 40 pizzas... Saw it was a car type event, gave it a rev coming up the driveway... we lold in pity
  • Like 1
guy who delivered our pizzas for the last tech night was in a very riced very thrashed RX8
He thought he was so cool hitting the limiter when leaving..
(he did deliver 30 pizzas so if it was 5$ a pizza he would have been in a good mood anyhow)
Yeah so it could be 2 could be 10 pizzas, typically you get to know the 'good tipping addresses' and race there as fast as you can so you get a good tip.
I remember this one guy, used to always pay with $50 and say 'keep the change' for like 1 pizza and a drink, baller probably in dezz's line of work
Edited by UNR33L
  • Like 1
While you were all at uni for a piece of paper, I was busy making paper.
i'm guessing you were an apprentice when other at uni, and from what I knew of tried apprenticeships straight out of school sucked massively.
best mate was a motor mechanic, 5200 a year first year.
another mate was an apprentice elect , around the samepay till hit 18, improved a bit,
but at 20 finished apprenticeship moved to perth and was on 120K doing work at the mines.
FIFO plus Union, PLUS explosives danger money...
(he was doing the electrical systems for the explosives carts in the mines)
where as his wife did uni, got degree, now a lawyer earning shit loads more than him...
  • Like 1
I finished school in 2003, didn't start my apprenticeship til 8 years later.
I'm not saying no one should go to uni or whatever, but most of the people that use the example you used above, forget to factor in the money they weren't making for the ~4 years they were at uni, so unless they're on mega bucks when they do get out, they won't be catching up/overtaking those who worked from the get go anytime soon.
Of course money isn't everything for some people, so it's not much of an argument, but for materialistic mother f**kers like me, it's pretty much everything
  • Like 1
But most people don't do law degrees and most lawyers don't even end up making truck loads
I cracked well over 6 figures at 21 never looked back
when I tried uni most were on ausstudy earning 200+ per week...so they were surviving fine for that 4 years.
Uni wasn't for me however, was sick of school no idea on what I wanted to be doing in 6 months even less for rest of my life, so got out and tried some stuff.
took this job thinking it would be fun for 12 months or so and now worked here for just under 15 years.
very true but not every Tradie does as well,
all comes down to drive and how much your willing to learn.
Still got plenty of friend from high school who did their apprenticeship, stayed in the country and happy to work from some-one.
so long as they can pay off their 150K (or less) home loan and afford a woodstock or UDL on friday they happy.
for every-one doing good there some just getting by and happy with their lot.
Big difference between survivng and doing well. $200 a week, $10k a year... I spent that on the engine alone in the R33
Like I said, not everyone is all about the money, that's fine. It's only funny when people with degrees/diplomas etc look down on tradies etc
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
