Then I realised I can do these things :P
crown wheel bolts used by eleventy models so that's no good. HOWEVER half shafts are only shared with R34 RB25DET MT so there's your best bet for a bolt in diff centre.
seems like a lot of moolah for just a centre... when i would consider even a viscous diff to be an upgrade.
maybe when i need to get rid of a lot money quickly... and then ill also grab these to fill the wheels
http://www.tunerwarehouse.com.au/index.php/products/product/view/125/1405
odie's D2's looked good today. i'd want low dust brake pads though, EBC seem to do some for D2's but the EBC daily driver pads ive got now make a bit of dust
Lol, grab a 34 Viscous, shove a 38424-40F67 shim in there, call it good :P. R34 also came in torsen LSD too. I think Alvin has one kicking about?
whats the washer do? after seeing Charles' torsen diff in action i dont really want one :P
sub 1:30 is solid time, especially for sub 200kw cars (except for 86's on semi slicks)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
