For some reason I feel like I want to buy a GC8
pro's / cons?
Con: giving your old man the bad news
Pro: glass gearbox...because hey, less time driving the car means more time for man lovin
I wouldn't buy one that didn't already have the 6 speed box.
they are cheeeeeap and I need a train station car that is still kinda enjoyable
tony has a civic for sale?
also, 2 weeks ago my dad recommended to stop torrenting for a few weeks... no one is going to track me down for downloading some 10 yro foreign tv programs so fuggit.
seriously just put a VPN in place and not stress.i was upgrading our router to one that supports it anyhow due to the Gov meta data crap
this just makes it more urgent
I'm using this on my table to get around country filters and hotel firewalls atm.
they have an app for a bunch of devices or you just put it on your openvpn router and your done for everything inside the network
https://www.ipvanish.com/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
