When I picked my car up from Creatd (wow that dates this story) on the walk from the station at 3:30pm I reckon I saw like 10 commodores come out of factories sideways spinning a singular wheel
Edit: that's totally a lie... but I did see 3 which is a lot when you think about it
I live in Frankston...I see this daily, dont even need to leave the house... :rofl:
f*k cats.
at least guinea cops or rabbits mow the grass.
Got sum bad nuwz Leigh
Whether you want a cat or not you got a cat lady brah
No way, I'd boot it over the back fence
On another note, my family dog is getting old :( like 15 years old had him since grade 6.. dem feels
Edited by UNR33L
Was at ferntree gully Nissan just before waiting for the parts guy on the phone... Someone putting rb26 in a gtt by the sounds of it ... Guy was explaing to the customer than the N1 model stood for nurgburgering.
Well done
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
