Was at ferntree gully Nissan just before waiting for the parts guy on the phone... Someone putting rb26 in a gtt by the sounds of it ... Guy was explaing to the customer than the N1 model stood for nurgburgering.
Well done
Akshully is because Grp. N and N1 being the class the GT-R's competed in.
i was thinking that becuz N1 pulsar had no ties to the nur, so yeah, guess you're right.
messin round with clutch fans and fan shrouds like a true RWD noob. they seem to work pretty well though.
My friend just got approved for a business loan through NAB, what are the odds of you having anything to do with that or knowing the person Hamish?
having to do with - very slim
knowing banker/credit partner/analyst/associate involved in the lend (via phone/email) - reasonable
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
