Haha nice one.
My total time commuting from boarding Pilbara plane to Melbourne doorstep is 12 hours.
Draining.
I saw them in concert when I played that epic failed Gatecrasher in the circus tents between vodafone arena and rod laver...
Never has the party over here, f**k you over there thing been so horrendously overdone
yeh, i get that, but what I mean is how is it supposed to be a problem?
Isn't that essentially why the brackets are re-done every 5 years odd?
if you go from $79,999 to $80,001 you aren't realistically paying any more tax (ok maybe a few cents annually)
Fkn left wing media :P
Welcome to the right my brother.
Mr Abbott welcomes you.
The only time your worse off for getting paid an extra dollar is when your just below the PHI/MLS threshold.
So that $1 extra pay rise means $880+ tax lol
I put these people in the same basket as those who blanket state that you get taxed more if you work a second job
I hear people say this every year!
So we've got an Installation Technician here at work, whose wife says he's not allowed to go and do an installation because of the venue...
Mens Gallery... Someones nuts are on lockdown, lol
Don't really want to send the hot german girl who actually made the sale, in case we lose her due a better offer before her probation period ends here.
And this chateau le blanc '68 is supposed to be served slightly chilled...this is room temperature!
If anyone gets that reference without using google then R.I.P funny man
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
