They only make a handful of decent looking ones if it's for the 5 series u need big wheels to look any good anyway which there is less of. Just leave it as is
true, saw one on 22s... LOL
Gonna put it out there
All BMW wheels look the same to me
agreed.
also BMW people are a very strange breed. very very strange.
they seem to be incapable of acknowledging other makes lol.
  • Like 1
With GM retiring all the reps wanna rock black wheels on their company cars now - he had/has a ban in place because he despises black wheels that much. When he ordered his S5 he paid extra to have the base model A5's smaller / non black wheels put on it lol
see, what did i tell ya.
just get some rotas and put ebay BMW centrecaps on. no one will know and you'll get heaps of BMW owners approaching you asking where you got em.
oh alex, get this.
had a little problem on friday, but was under pressure, and had to head over to the storage warehouse to measure something up.
anyway, young bloke we had hired had gotten a bit comfortable.
sends me a msg saying "youre a shit talkerwhatre u going over there for"
i reply "excuse me?"
to which he continues being a smart arse.
did this flamin mongrel really say that to his boss?
put him in his place when i got back to the shop...
not sure if i should warn him or forget about it.
I've always wanted push button indicators on the steering wheel where they usually put the remote volume controls - anyone know if this has been done in a car that isn't a million dollar supercar?
Really liked that about the 34 auto; placement of the tiptronic buttons
oh alex, get this.
Well without context it's hard to say I'm going to assume that you talk like that to each other regularly so although he is out of place it's tricky to tell him off as you've created that environment.
Flip side it's a strictly professional environment and dialogue in which case official warning and move on hope he learns a lesson.
Kids these days...
Edited by alr33x
Dude it's not a 33...
So I'm down to 428 or 435 struggling to separate the two aside from price difference as the 428 by all reports is just as good and only .6 sec slower to the 100kms but 4 cylinder feels ghey.
Or should I just accept that's the way of the world now turbo whipper snipper motors?
Side note would prefer the Lexus but nobody seems to be buyin em so I'll dodge a future sc430 scenario
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
