24 hours of lemons at wakefield on the 28-29th of october
seriously thinking about entering lmfao
car must be under $500, including mods, excluding safety gear and tyres
what the f**k can me and my mate buy that will hold up?
would anyone else like to form a team?
You can't get a $30,000 car to hold up, what makes you think you can do it with a $500 car
$500 gets you a lot of car when you don;t want to think about rego.
want some turbo charged Euro fun
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-163018&Cr=4
maybe do it in some bogan style.
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-3278450&Cr=1
but for yourself...I think look long and hard in NSW for a lancer with a evo body kit or a droid body kit with as much autobarn blight as your can find.....
then enjoy killing it.
(ie find a car some-one advertising as an ex autosalon show car..)
aye aye aye i made it to sydney and back and had to rescue a new focus and a 180sx on the way back lol
Yeah I was like that at my last job.. felt like I was getting dumber not stimulating my mind, I was starting to forget things in my personal life too.
I could seriously do 1-2 hours work a day and sit online the rest browsing stuff, every work day! (within the last 6 months)
New job don't have time to scratch my ass and 2 hour + longer days :\
Edited by UNR33L
Got into counter strike this week.
I enjoy the friendlier-smack talk, but fark me it's a sad world. Thousands of hours of play time, sitting on the same map, using the same weapons.... Worse than wow almost. Except it's stimulating (for a few hours)
Any of you liberal kunce know what the government's desired productivity % for various industries in Australia is?
ABS will have the raw figures, not sure about targets / projections. Why? Edited by HEKT1K
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
