So do all the corporate knobs on my site who know sweet f**k all about anything to do with actually working on site, and not in the office on site, or what their handbook tells them should be done
sorry to hear there is an 'us & them' culture at your site. The corporate panzies should try & fix it instead of waving their own power-card.
Respect for both sides will always lead to a better resolution.
What about the repercussions if Leigh's room-mate complies with his demands? You will only create a tense environment in his own home & the room-mate may take out his disapproval in other ways.
(Letting her stay until midnight each night - if you only said she cant stay the night etc)
Dont shit where you eat.
Sure he can kick him out & go through the effort to find another room-mate but if all of this could have been resolved by having a respectful 5min conversation, things could be a lot easier in the long-run.
someone gained access to my internet banking account & opened two bank accounts.
They then hid the bank accounts under Options so was unaware.
They then transferred money from my savings account into the hidden bank account.
Which they then used PayPal to withdraw the money.
Only way you can verify a bank account with Paypal is to confirm the deposit amount made by PayPal.
Got the bank to block the two accounts, now i need to chase up PayPal for refund.
There goes $1600 :verymad:
That's shithouse Pat
Surprised you can open a new account online without all your details?
Almost everything I do in netbank requires a passcode sent to my phone
I also look over my transactions pretty regularly to make sure there are no suspicious direct debits etc. How'd you discover the fraud?
Once you login, its only a few clicks to create a new bank account. Only if you transfer money you need a sms passcode but payments are deducted instantly (such as PayPal deduction)
The guy must have slipped up, he left one of the accounts visible which showed -$400 overdraft. Went digging around & found the hide accounts option & discovered another account hidden.
He managed to transfer 2x $600 from my savings account into the hidden account & used PayPal to deduct the amount.
Picked up that I had missing $1200 from my existing account, however if he hid the overdraft account there would have been no trace
shit thats f**ked. why would there be an option to hide an account? so when you log in people (aka your partner) cant see you've got a secret account?
your money should be covered by the bank because...
a) they hacked their bank system
b) created a bank account and transferred money from said account without your permission or knowing
you havent done anything wrong. its not like you used some dodgy smart phone or ATM and entered details of your account. if its via the banks website or system then its their security breach, not yours.
(when in NZ my card got scanned by an ATM and someone started withdrawing from america. barely spoke to commonwealth about it due to reception, but they gave me all the money back within a day)
yeah I reckon, they blocked the accounts & gave me PayPal's phone number to call. It gets tricky, cause PayPal will refund to the new accounts which have been blocked. Will then have to go to bank & get them to transfer it back into my account.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
