Tony Abbott's icing on the stupidity cake that Joe Hockey baked yesterday...
"Even as a cabinet minister sometimes it's hard to pay a Sydney mortgage"
Srsly.
"But Hamish, what does a cabinet minister make?" I hear you ask...
Oh, not much... Just $330k p/a
Lol... Just... lol...
Srsly.
Even if the meaning is taken out of context - and he probably is talking about big houses in expensive areas - ahat I don't get is why he would say that comment in the first place when it seems to contradict what Hockey was saying; implying that housing affordability is so bad that even cabinet ministers can be struggling?
meh whole things a beat up. If u can afford it buy if not rent. Been that way since I dunno forever.
Houses are expensive in basically every first world country - do you think London is affordable? New York?
Edited by alr33x
Ten hour night shift went surprisingly fast... 7 to go
I don't even want to know what (presumably rediculous) penalties your union has imposed upon society for that...
Anyone got a guard roller they're willing to loan out to me for a night? Alternatively anyone used the eBay ones? I've heard they're shit lol
I'll lend you Aaron for a night but must be back by 12 and strictly no bruising
  • Like 1
I just worked out what this whole GF staying over thing reminds me of.
https://youtu.be/agY_oPHL62E?t=1m22s
Seems Leigh is Dr Sheldon Cooper.....
haha i thought about that actually the night I spoke to him bout it
hey if he don't like it he can move out!
  • Like 1
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
