I try and warn people the PFC is a 20 year old piece of dinosaur tech, and it's worth $20 in the scheme of things. There have been better options for many years but everyone still gags over them.
The beauty of the PFC is experience with so many tuners and the ease of replacement if you get EPA'd
I've had det on E85, when I had an intake leak and it was running too RICH...
That aint det Simon, it's spark breaking down.
I had det on e85, but i was running 22:1 on cruise while fiddling.
Any plug in ecu would have the same benefits, Haltech do a plug in too.
What sort of power/torque increases have the 86 people seen from it?
Not sure, the guy was SAU so it wouldn't be hard to ask... There were two running at PI, and I know at least one was on e85, the one in my group.
I wouldn't buy one these days with adaptronic and haltech available, but I've had mine for 5 years and rather than getting another 98 tune done on another twice as expensive ECU and then getting the E tune on top of it, a simple retune for E was the viable option for me.
It's still popular because every tuner can do them, they are plug and play and cheap and do the job just fine for all but serious racers. People love the hand controllers too lol
hey guys booked it in with freddy at nisma in thomo for that 700rwkw methanol tune with 9s and gt42 with 2 speed powerglide hollinger.
wot could go wrong?
Don't forget you will need twin SUS power filterz mate for that power.
Not sure if mocking perfectly sensible concept
I just don't see why some douche who did a medical degree for 6 years or put in the hard yards / cut back on spending habits when he was younger should own his own house when I'm stuck renting in Richmond and can barely afford music festivals let alone the repayments on my 3 series
  • Like 1
saw some article posted on fb about this 24 year old havng like 4 houses worth 2.3mil, from a 'rich family' but no handouts were given, yet shes earing 55k a year.
Yeah right LOL.
She was going on about how anyone can do it etc.
http://junkee.com/sydney-property-market/59596
I get 10L per hundred from e85 in the Evo, on the open road. Pretty good, but I doubt you will get that with the V8.
Yeah on 98 I'll get about 8-9l per hundred cruising at 110km/h just purrs
Actual city / daily driving it sits at about 15l/100 on average, about what's expected I guess.
Yeah right LOL.
heard ric once paid a bitch 2.25mil to suck his dick...
Birds, get Nistune and flex.
Done.
Last time I spoke to Trent he said 86's make something like 110 kw stock, and 145ish on E85 with nothing else done.
He also said they were pretty terrible car, widly not worth the money.
1:51 at PI doe...
Sorry Birds, he was in the 86/brz club. Craig Furniss with the BRZ, managed a 1:54 I think.
I'm surprised more of these guys aren't doing the supercharger or turbo conversions; that chassis has so much potential as a track car
Must be too new for people to want to risk their engines lol
Done.
1:51 at PI doe...
Each to their own but there's nothing else for the same money that comes close in looks, handling and rwd...there's a reason they're farkin everywhere these days...Toyota found a niche and filled it. They will be the next big P plater and tuner car once turbo/blower conversions become more widespread and the second hand market value comes down a lot.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
