Vic WL
My 040 in tank pump has been noisier than normal for the last month or so. Thought it was my imagination being overly sensitive to all the sounds my car makes (Skyline paranoia) and Leesh telling me she can't hear it.
So I took off from the lights today showing an HSV how it's done and hit a brick wall on high boost in second; thought I'd done a cooler hose so putted off boost to my destination and popped the bonnet. All hoses secure no sign of a break in. Fuel pump quite noisy on idle now, and especially noisy when the variable voltage kicks in with throttle on...Leesh can hear so it's not my imagination.
After 5 years of faithful service, is the 040 dying a slow death? Now feels like I'm driving a ticking time bomb. Gonna buy another one but fearing there may be another issue at hand. Is it possible fuel lines / filter / rail have a blockage and the pump is noisier because it's trying to suck a softball through a straw?
Started getting noiser pre-98 octane switch, but now feeling like the switch has aggravated it further...possibly because I ran the tank pretty dry or the 98 has caused some crap to unclog and re clog somewhere?
Sincerely,
Birds
inb4 get a different pump - if I'm buying a new pump another 040 is going in! 5 years is nothing to sneeze at and 2 of those with ethanol when it's not even sposed to be compatible with it.
get walbro.....im on my 3rd in 5 years...at least it quick to change now.
I swore I'd never do another 33 in tank pump again after the first installation...it's a nightmare for anyone without spaghetti arms. But here I am...
first time had to modify the loom for the pump as well for the walbro, and think the s14 tank as bad as the R33 one.
could be worse, to do the one on my ute you have to remove the tray, or the whole diff assembly and then the tank.
Birds
040s get f**king loud when they start dying
Source: killed multiple
Get a 460 pump and for gods sake redo all the wiring in one hit
Yes it is annoying
But better than doing it 9 times and WAY better than having your car die because you have a powerFC that wont save your engine by cutting all your fuel when you hit 18:1 AFR on 20psi.
  • Like 1
Birds
Yes it is annoying
Appreciate the concern but I don't see it popping my engine anytime soon while I'm driving around off boost. Worst case I end up stranded and needing a tow. It already leaned out on me today on boost, that might have been a lucky experience but now that I know it's on the way out I'm driving cautiously. That this one lasted 5 years is a good enough interval for me to suggest I installed the first pump properly with good wiring and in a good position - plenty of people kill walbros/Nismos/bosches in shorter time; replacing fuel pumps is just a fact of life for modified cars and in-tank pumps that cop abuse from tracking etc. Everyone replaces them. The 040 is cheap and to a degree it'll be take out and drop in cause the hose lengths are already cut for it and wires soldered to correct terminal size. Fk doing all that again for another pump type. Tell you what if this next one goes I'll get a 460 :P
Also gonna keep the variable voltage setup - think this may be a reason for longevity of the pump as a lot of the time it was cruising away on low voltage mode. Also keeps it quiet.
I just find it suprising it supports the power you're making, i.e 270ish on E85. Would have thought itd be close to running out.
If it meets your needs its worth doing it again, but the 040 certainly certainly clogs up more than your average bear.
Mine was doing 335kw on E85 with still room for more.
Also lol Birds you cannot complain about a 33 GTST Fuel Pump fitting. The only thing easier is a 32. Try fitting a pump in a 34 GTR!
I'm surprised they're not more popular than they are (and they are popular). See people doing lift pumps and twin 044 setups in street cars lol?
A single 040 can flow 600hp+...shitloads of headroom on this pump and at $160 why bother with anything else!
Interestingly Just Jap say not suitable for E85 but this website does http://www.dp-engineering.nl/bosch-040-motorsport-in-tank-fuel-pump.html
On that note, anyone know what makes an E85 pump an E85 pump? I'm not sure I buy the gimmick when I've been running E85 for longer than the designed for E85 fuel pumps have been around - where is the test of time?
Come around after work and fit my new 040 - will supply tools and pay cash more than RP pay you by the hour!
That^
I don't understand his logic...if he took it apart and found impeller blades corroded away it would make sense...but he's showing the mesh covered in sediment? These pumps sit at the bottom of fuel tanks and suck lol
He'll get a shock when he pulls out the walbro in 12 months and it looks the same...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
