My bin day doesn't align with my FIFO roster. I'm forced to either let my bin sit empty for a week on the curb or throw my rubbish into someone's dumpster. (Need to confirm if it's not cardboard only dumpster)
#Fifoproblems
Surely you'd know swan and pendles,
Sometimes I'm home late from work or don't put my bin out, good guy greg (not actually greg) neighbor in the other unit puts my bin out or pulls it back in. He also does my gardening (although he'd be paid by body corp for that I'm assuming) because he doesn't mow my lawn on my 'actual land' but at least prunes the bushes n shit. :D kinda a weird setup but got my own second driveway / front bit.
Edited by UNR33L
lol i hate it when that happens. I usually had someone grab my mail once a week so would ask them to do it. then neighbours when bring them in. #rowvilleretirementvillage
Haven't met the neighbours yet, probably some baked hipsters.
My car is very loud in garage. Can see a noise complaint coming through soon.
Can't spot any of the famous older ones, they may be in business or another flight.
You have land?
You have land?
Yeah, there's 3 units on the block with a shared driveway and owned by body corp / all the garden, grass etc maintained by them on the left side of the block.
I have a front lawn which is mine next to another second driveway on the right hand side of the block which is mine as well basically back entry to my place and can drive into my back courtyard.
The guy that does gardening stops the mowing at that line from where I own (which is a bit annoying if my grass is getting long) heh
The number of times I've had a flight attendant purposely jam their trolley into my ankle that is resting slightly in the aisle
There's one passive aggressive male flight attendant who does it everytime I see him on the melb to perth virgin flight
yeah they would not be doing that to me.
Maybe he wants ya?
  • Like 2
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
