Doubt it
There's another one who probably does though, always got extra drinks/meals from him and spoke overly polite to me
mmmm that fine line between unable to determine if someone actually just delivers good service or if they want ya.
I blame all the horrible service that seems to be standard for blurring the lines
lol happens all the time to me, I think that I attract a hell of a lot of gay guys
You're right - guess it's never been easier to hit on someone with good service alone these days
I'm also overly polite dealing with strangers so I'm probably inadvertently bringing it on myself too
Yeah I'm the same I like to think I was raised properly these days people are so freakin rude but my mum always says you'll get a lot further killing someone with kindness
Good service / hitting on can be confusing but what really messes with me is when they make an effort to ask about your day / what you've been up to today. Again it could be innocent and just someone being friendly but my instant thought is why does this person wanna know that?
I guess because strangers don't really make idle conversation with each other too much these days like they used to. Always see some old guy in the supermarket just talking to the register girl about random shit and it looks like he's hitting on her but he's probably just doing the olden day thing.
It's true
People read my forum posts and probably shocked in real life to hear me say "thank you very much", "thank you so much", "you are a champion" or "excuse me, can I please.." along with smiling, but it gets you so much further than demanding shit like everyone else seems to do. Manners manners manners.
  • Like 1
Stop wearing a low cut top
It's hot so I'm wearing short sleeves but it's cold so I'm wearing jeans but it's hot so I have a V cut in my top but it's cold so I have a hoodie on but it's hot and sunny so I'm wearing sunglasses but it's cold because of this fog juice but it's hot because of the stage lights on my back but it's cold so I'm keeping my hands in my pockets
  • Like 1
Got off the first one, which was $185 then I couldn't get off the 2nd obviously which is $295
So coughed up the $295, stupid slow speed limits
One was on bike one was on car.. both times pulled up by hwy patrol
83 in a 60
96 in a 80
Edited by UNR33L
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
