Gee you're so impartial Ham
Sure am... ain't my fault the incumbent PM is a misogynistic, homophobic, biggoted, xenophobic fundamentalist christian turd sandwich that came to power on the back off another parties f**kup and a bunch of 3 word slogans aimed squarely ay bogan australia....
Let me know when you're done huffing and puffing, so you can acknowledge that it was your ideological compadre Bill Shorten who uttered the above (in the context of being questioned over what a slimy prick he was and is)
  • Like 1
Martin nailed it.
I have 1 teflon pan only and the resf are seasoned cast iron
Industry standard and completely non stick if you look after them
room mate f**ked my good pots and pans up with a scourer, annoyin
Draggin bikes I don't mind when people do that - never know how shit a rider could be at launching, but when cars try to race bikes playing traffic gaps, it's just dumb
I remember when I first got my R1 and outside Knox had a 911 turbo behind me at the lights - was the first time I properly gunned the bike and I scared the shit out of myself. He tried to stay with me and from that moment onwards I declared bikes to be awesome!
Have beaten a few naked 600s in my car off the lights, even a CBR600 was surprised in the traffic when I was running ethanol; asked me how much power I had at the lights. It's not impossible to beat bikes but they do it so effortlessly...really have to try with a car.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
