There is no policy that could produce that sort of result; what I term the idealist/utopian corner.
This explains a lot of Greg's car troubles - he's a fkin dreamer!
  • Like 1
I did the most recent one (wasn't 2013) and I finished up in the top right corner.
I am the 0.000001%?
Was aiming to be part of the curve... Spun a bearing and a wheel exploded, spun out and ended up in a busstop / top right of graph.
Because Greg.
Talk about decadent
#topicalhumour
Related anecdote: found out the other weekend that my best mate in years 7-10 high school (peak of adolescence) came out a couple years ago. Now recounting my memories of sleepovers/parties/allmaleorgies for signs he was in the closet.
like the time he convinced you to fist him?
  • Like 1
What about the times when you used the word "gay" in jest within conversations.
Now realising that it would have been many bad feels for him.
  • Like 1
You telling me the man who try to put a rubber fist in your anus was a ho... ho... ho... homosexual?
Your change management has no place in our altered state of friendship
What about all the times he told me he thought some chick was hot - lies, all lies
FYI he used the homo words in casual convo too. I'm thinking he was in denial (now he's inda anal) or just wanted to fit in (oh god with the puns)
  • Like 1
Wait a minute.. didn't you and Simon go to highschool together..
It all makes sense now
  • Like 3
Recently found out my friend came out of the closet although he hasn't publicised it & probably thinks I don't know.
I can either confront him, apologise for any in-jest comments & make the situation awkward, or wait until he mentions it & either pretend or admit I knew to which I would have to apologise & make the situation awkward...
Im sure there is some tv series which has addressed this issue. Not that there is anything wrong with it.
  • Like 1
Unless he's feeling awkward about it and calls you up on it, I see no reason to make a thing out of it. Unless he's an egocentric flamin mongrel he's probably also aware that you might be feeling awkward about your in jest comments over the years. My personal view outside of the humour I post in here is that sexuality doesn't change what that person is to me, no more so than what kinky things a heterosexual person does with their wife in their own time that's also of no consequence to me. Sexuality is just another characteristic of the person - skin colour, big ears, tall or short, shy, intelligent or dumb. I therefore don't believe it should be off limits for jokes or mucking around. My brother is gay and I still pay him out with those words on occasion, not because he's gay but because I'd say them to anyone else too. Him coming out doesn't change this because I don't think sexuality should impact or change how you treat someone either. If he said that it offended him, I would be more sensitive to it around him just like I would anything else I say that offends people.
But I would probably also engage in a discussion about my other view on gay slurs in casual conversation: I think that once upon a time they were used exclusively as an insult with the implied connotation that a homosexual was inferior or different in an unacceptable way (and sometimes still are used this way), however the more common use of these words as insults these days, particularly amongst teenage guys, has its own meaning which is far removed from the gay bashing it used to be. Consider that many teenagers using such words don't even know the full extent of their meaning. This is why I'm not apologetic for any instance of using such words when my intention is not to hate on gays.
However - like anything else I say, if someone were to take offence I might be more sensitive about it afterwards (after explaining my viewpoint), not because I necessarily agree with them, but simply because I'm not a total flamin mongrel and I'm more for keeping the peace.
I also wouldn't retrospectively apologise for what I've said not knowing they have taken offence to it - if someone takes offence to something at the time, the it is up to them to call you up on it then and there, or else they are more or less condoning it to continue by way of you thinking they are okay with it. People can't change if you don't give them opportunity to or the boundaries to play in. I might be more sensitive towards a topic from there on if someone has made it clear they are offended by it, but certainly wouldn't feel I've wronged them in the past.
tl;dr: I don't hate fags
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
