Took the day off work and I'm sitting here patiently waiting for The Thread Doctor to arrive.
Removing a snapped dump bolt from my turbo rear housing, and 3 exhaust mani studs from my block.
What are you guys up to today?
I'm at southern grampians volunteering by setting and catching bandicoots for research O_o
Dat corporate volunteering
lol no worse?
you're in for a suprise lol
its not even so much economy.
major PITA having to fill up all the time because of the small child sized tank..
that and the turning circle lol.
the only two faults i have with the car...
replacing the o2 over the weekend to see if it makes it a little better as the o2 looked as if it was all over the place.
currently 250km to a tank.. stock. fun. no
that's ok... i'm not worried by the small tank... also 250k/40l is about the same as the skyline and that's not tuned... it should use less fuel but by a bees dick
Yeh, it seems ok, i just think I'm worrying too much and giving it abit too much boot. But when people are saying they normally get 320k out of a 7 tank..
Well...
37 litres i filled up to be exact..
got 252.3km lol
apparently tank size is 48 litres
which is bang on correct for 320km to a tank lol
i've literally calculated how paranoid about stupid shit I am haha
Watching Sopranos re-runs and job seeking.
And sorting out my farkin coilpack issues.
coilpacks +1 :(
need some new puppies in mine too. but mine have been dying for a while LOL.
coilpacks + major = happy days
hopefully.
*soon*
+ 1
Coilpacks letting go after 160,000K and hitting 19psi today
All my bolts came out fine only took a few mins
Me got my car tuned at Chequered tunning today
Fuel economy is for pussies.
+ 1
lol no worse?
Yup noticed the fuel economy in the Evo wasnt that great
And the turning circle is crap lol
What'd you make Toby?
Guy in an excel was driving behind me this afternoon, taking a photo of my car on his phone. Were u mirin me Dezz?
Coilpacks were failing so atm 265 rwkw on 19.5psi with a boost drop to 15.5psi at redline
If I sort out coilpacks and boost drop trent reckons should hit 300rwkw
Guest
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
