Different cruise brah....
Am aware...but just talking about the spur or any roads up there reminds me of him.
I'm convinced he was a professional troll. There's no way someone could be that stupid / that much of a douchebag / that much of a stalker. And the wheel swap confirms it.
inb4 he converts the front end to an R33
Someone buy it or at least read the ad; I put a lot of effort into the sales pitch
http://www.skylinesaustralia.com/forums/topic/423621-fs-apexi-power-intake-pod-filter/
no way he's a troll man... I wish I could tell myself he was... I would sleep easier at night knowing he wasn't out there
wow!
5-7k. Not looking for anything flash. Just has to have 3 pedals
pulsar?
I should become the Pulsar Used Car Salesman here... trying to convince other people to advertise their cars on here because lots of people avoid carsales/gumtree for many reasons and no one on PGA buys cars.
Stalker Stoppers International
4 February
"PLEASE NOTE"
"This Business is Under Construction Until Further Notice & is Not open for Business at this time"
I APOLOGIZE FOR ANY INCONVENIENCE.
If you have a stalker of your own & if you have any questions regarding your safety please post a question on this page & I will endeavour to try to give you advise or hits on how to help keep yourself safe from stalkers until we are open for business to help you more directly.
"THIS ADVISE IS FREE OF CHARGE"
Thank You for Your patients at this time.
I'm guessing he calls his victim's "Patients"
lol I remember him setting up that page. That was probably the scariest thing he did IMO...it was like a dumb criminal trying to set up the "perfect" alibi. He couldnt be a stalker, he's from stalker stoppers! That made me think he was properly harmful.
we are talking about a guy that thinks paris hilton is going to visit his house in benalla and says goodnight to alyssa milano via twitter EVERY NIGHT...
then there was the spotted thread saga...
def not troll
Guest
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
