Nah Adam, ethanol does burn slower than petrol. It also burns cooler due to the hydrogen bonds in etOH, which requires a lot more energy to vapourise than petrol. Explains the lower EGTs when running etOH huh? Fact in point is bubble point of etOH which is only C2 is 70degrees, it is a trend that the more the carbons, the higher the bubble pt (high school chem i assume).
Petrol is basically C8, with various isomers and aromatics added in to increase octane rating, but they all have roundabout 6 to 8 carbons, and no oxygen in the molecule itself. Petrol itself boils at 90degrees, but the components are largely C8.
We can look at vapour pressure and heat of vapourisation to understand volatility. 896kJ of energy is required to vapourise 1kg of EtOH vs 298 for octane, which is the closes to petrol. This, is why it burns cooler and slower. Or at least why i understand it burns cooler and slower. I'll have to look up activation energies to further explain why etOH burns slower but i cbf now.
And that is why, it is probably better to go a hotter plug when you're using etOH as a fuel.
Had a headache by the end of the first paragraph you Kent's are too smart for me
Lol Alex, I was about to say the same.. Lol the only reason I know that ethanol burns slower is because I set it in fire at Scott's lol
I like fire
But yeh the bigger arc/gap makes sense!
Awesome thanks for the /skylinesaustralia discussion in the wasteland.
Thinking of buying bcpr7es-11 to see if misfire caused by heat range of plug. If issue still occurs, I'll drop them to 8mm?
Thoughts on this? Cheers
About to happen to me... very hungry so call my mate to go Subway/Schnitz.
Then Pho is brought up. Also very acceptable. Nek minnit his missus also coming (which is no problem... the problem is that she doesn't live *close* and now I have to wait longer until my food is in front of me :'( ).
tl;dr
getting pho, but have to wait :'(
Edited by kaitoukid
I'm still gonna say go to .8mm. I don't think you are chasing 350+kw I mean mine were .8 on all my cars. Never had an issue with making powerz
http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqpregap.asp?nav=31200&country=US
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
Interesting...
It does burn cooler, but from what I'm reading, not slower. Google has some conflicting results...some say faster, others say slower...and this also seems to change depending on AFRs too. Ethanol does have a higher autoignition point, making it less prone to detonation and harder to ignite than gasoline...but from what I understand, once ignited, will burn faster. I would like to know which one is correct, is there a way to test it without blowing ourselves up?
One thing is for certain...ethanol is awesome.
Ethanol burns slower but an increase in pressure changes it's burn rate drastically. There is also more oxygen to help it burn.
I have seen nearly 1000 degrees C in my manifold, so it certainly doesn't burn cold, just colder than dino 98. This is mainly due to extra timing though, as adding timing gives the fuel more time to burn in the cylinder, not in the exhaust.
^^ This. :)
well, burning both fuels at atmospheric would be very different to burning both fuels under cylinder conditions, cylinders have pressure between 160 to 200ish psi? that's from 10 to 15x atmospheric pressure.
mr aero engineer, any input?
Guest
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
