tyres for steerers.
what do you all rekon? while torching tyres is fun.
i got my hands (practically stole) on a pair of ad08rs to keep the rear planted
So... put some AD08R's on the front... Front grip is more important than rear grip... Unless you wanna understeer and make sweet love to armco
tyres for steerers.
What size?
Im trying to get rid of some Hankook Rs3's
How badly you trying to get rid of them
Depends how much your going to low ball me.
I don't mind getting rid of them, but not desperate. Know what I mean?
Thought about just wrapping them up and keeping them, but that also clogs up my garage
They are also currently on rims so i wont also need to pay to get them off em which is a pain :/
My R1Rs are wearing down but not dead yet so how much I low ball you depends on how much you high ball me
Didn't you have another set too?
I got 2 x brand new ones 265/40/18
and 2 x worn ones 265/40/18. I haven't measured the tread but maybe 60ish %?
Take the driftek rims with it and get the whole lot cheap cheap
wont be tracking it any time soon..
too much shit to pay for .
You really want me to give up my D1Rs for some cheap common wheels?
Will PM you about the tyres. Do you know what year of manufacture they are?
i just had an asian family walk into the store, and everyone had an aussie accent.
when i say aussie accent, i mean, like birds after hes had one too many vb's some pingers, a point of shard and a hoon around in a VN 5litre.
mind blown.
Pretty sure they are 2013 manufacturer. Probably mid?
Guest
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
