Hmmm that one can sometimes take the input shaft with it, hopefully not yet and it's just on it's way out.
Outside chance, but can also be a clutch issue. Thrust bearing another slight possibility if it's rattling around on the input shaft retainer because it's slightly touching the pressure plate (a good way to test out this one is to put a small amount of pressure on the clutch pedal so that it presses the bearing firmly up against clutch, but doesn't engage the clutch...if noise disappears then it's probably this. Otherwise input shaft / spigot bearing is your culprit.
Might as well do rear main while you're there too.
Any IT gurus here can point me to a cheap/free webhosting service?
Just need a service with cPanel so I can setup a catchall email forwarder.
cheers
I've used crazy domains in the past, seemed decent.
Stop being irrational
Ordinally, I'd intercept here with an acute pun/expression derived from mathematics, but my obtuse, two-dimensional humour oddly does not appeal to the lowest common denominator, only outliers like Ric and even yourself...plus I don't want to be mean and ruin the mode, so I'll be a square and stay out of this 1. But I regress.
  • Like 2
We're very proud to make you a member of our very select group. Welcome to Super Friends.
Welcome, Super Friend, I am called Ham, because I enjoy ham radio.
Missus dad hired skip. filled it up to level on sunday.
Wake up monday morning and theres a shit load of crap on top + bathtub and hot water system.
What the f**k.
What did you expect...skip belongs to the neighborhood between 7pm and 7am
  • Like 1
If it means me waiting more time to get in cause your car gets priority...hell no
Nah mine will take at least 6 months we're predicting as customers will always take priority no matter how late they walk in the door through my build :P So I'm currently in the process of buying a daily for the long haul. Theres 3 engines being built in the engine room atm, all of them RPM 2.8s. I was merlin when I walked in and saw 3 new crankshafts all just sitting there..
*ahem* engineer whose specialisation is statistics checking in & you reference the lawyer
Guest
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
