i couldnt find a pic, but has anyone else noticed the blue-tinge windscreens on some 7-series BMWs and renault scenics? (im sure there are others)
It's a silver oxide coating in the glass. It reduces UV and heat getting inside the cabin.
i must have this.
also, thinking about doing purple brake calipers. will match kikumusubi knot and interior LEDs. possibly engine cover in the future.
pretty pumped to get car back with new alignment + wheels. apparently S13 LCAs didnt line up at all... will speak to the shop during the week. hopefully get some money back on re-sale.
Timer was 1:01:xx when I ran through. But started later cause purple. So estimate 45-50? How about yew?
Yeah man feel sorry for the babies. Some people were going fast as fk with their prams, weaving in and out of people. Was thinking, would be very ugly if they crashed or something happened.
peak physical condition .. Ease up moneghetti just do for the funz
What's the real-estate cycle? When do new properties typically get listed?
What's the go with the Easter rush? Why is there a massive drive to sell before Easter? What happens after Easter?
Guest
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
