Yeh deffs tony just sounds like a mega rip thats all I know they charge for the name and that but that's daylight robbery! LOL
pic of diamond high roller!
I'll try to tonight
Lol you're all getting ripped. You're talking like you're wearing the diamond yourself
It's all a dick swinging contest anyway, successful marketing at it's finest
If diamonds are a rip, when the time comes what are you going to propose with mang? :D
Happy to spend a reasonable amount, but not gonna blow that much of a wad of cash for it!
exactlly at the end of the day Katie gets the ring she wants and I pay what I think is a reasonable amount.
All I can say is forget the discount chains and the Tiff&C and you can get something very reasonable for a good price.
and really for something will last your life it worth it.
yeh bit sour dezzmang.
i mean they keep it and wear it forever i got no issue spending a bit on it not saying id spend $30k though! its relative to what you can afford but i wouldnt be comfortable with some shoddy ring with a small/average diamond but its a personal preference not like there are any rules!
Tony: I'm sure your mrs would've still said yes to a ~3, 4, 5k diamond..
I see it as a waste of money spending 20k to wear on your finger, especially when you're driving a skyline and not some high roller, but thats me
If i asked my mrs if she wants a 20k ring or a 3k ring and a 32GTR, I know what she'd say
true dezz i'd suggest if you were earning say 150k your missuz might expect more than $3-$5k ring, just assuming so could be wrong.
bottom line is you spend what you can afford and get the best thing you can for that budget
I don't have a girlfriend and the ex just went to Japan ffffffffffuuuuuuuuuuuuuu woulda been cool but ell well - forever alone.jpg
Nah mang, you can go clubbing every weekend pickup bishes, do whatever you want without a care in the world!
Guest
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
