So which option give you 40 million?!
for final heist? dunno - i ended up using the people that cost the most for 100% sure completion (instead of losing shit like i did in the first heist by cheaping out), and doing the sneaky approach. ended up with ~20mil per character, plenty enough for what i need. i do like the idea though of doing a replay but not doing any of the assassination missions until after the main story if possible - can then spend massive dollars on investments instead of like 100k.
ah wait here we go
  • Hotel Assassination: Invest in BettaPharmaceuticals (BAWSAQ) before the mission. Look for a 40-50% return.
  • Multi-target Assassination: Invest in Debonaire (LCN) before the mission. Look for a 80-90% return. Immediately invest in Redwood (LCN) after selling your Debonaire stock as Redwood will see a 300% increase within days.
  • Vice Assassination: Invest in Fruit (BAWSAQ) before the mission. Look for a 50-60% return.
  • Bus Assassination: Invest in Vapid (BAWSAQ) after the mission. Ignore any graphs or green/red arrows, if the stock value is well below the "low" value, invest. Look for a 80-90% return (I had to die once before there was any change to the stock).
  • Construction Assassination: Invest in GoldCoast (LCN) before the mission. Look for a 80-90% return.
the fifth one on that other list is a random event as you drive up the west coast - dude wants you to get him to the airport and gives you a tip when you drop him off; 30% return on it.
BAWSAQ is the online one but certain stocks affected by in game actions (a la Lester's missions) are affected as such temporarily.
Sped through the main missions on my second run. Finished yesterday.
Did all of Lester's assassinations this evening. Had about 32mil on each character after final heist. Played the stocks as people have said: cpd put up the most concise guide so follow that.
Made Franklin a billionaire (he's my main guy, he owns all the properties), got a bit Lazy with Michael, only did the pre-mission investments for immediate cash in, more than enough for all his cinemas.
and couldn't give a flying f**k about Trevor.
Yeah, I had heaps of trouble at first with Trevor - too much of a psycho, and how he treats people. Had to skip all his cutscenes.
He seems to mellow out to just being weird by the end though, so it was easier to watch.
Gonna have to run through again; can't wait for PC and 1440p and mouse aiming though! Stupid thumbstick. Would give up auto-aim for mouse any day.
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
