Anyone else experiencing problems with this site or is my computer bugged?
1. it often does not display properly - just a narrow band on the middle of the page.
2. Mostly I cannot access my messages unless some PMs me in which case i can reply
3. Sometimes I cannot reply to posts
4 Often I cannot edit my own posts
A different issue which has been going on for some time is that when I try to close links which have been posted the website cloess instead of the link.
Anyone else had any of these problems??
https://www.sau.com.au/forums/topic/384869-problems-with-this-site/
I have Mac and run firefox and for the last 5 days having problems as above e.g displays as narrow band.
I logged out and took me forever to log back in and had to do it via crapbook.
I cant edit or even display my settings.
I've tried in safari,Firefox and Google Chrome and same problem in all browsers.
:wacko:
Thanks mate - I'm not going mad!
Loaded latest update for Windows 7 (which displays all other sites with no problems) and then down loaded Safari - which is even worse - can't even log in!
Will try to make a note in the admin section.
OK I can't even open a thread in the Site Maintainence/bugs section.
Could someone who has no problems kindly paste a link to this thread in that section?
Thanks
Bob
http://www.skylinesaustralia.com/forums/topic/384869-problems-with-this-site/page__gopid__6139284#entry6139284
Now that the Mac fanboys have quietened down...
I have no problems with Win7 and Firefox, Mac and Firefox or Chrome, Ubuntu and Chromium, iPad and Safari, or Android and Chrome. Win7 and MacOS are so close these days there's really bugger all difference.
Get rid of Internet Explorer and that should help.
I've always used win xp, firefox and had no issues, same with ie.
In IE try going to the tools menu and turning compatibility view on/off and perhaps clear history/temp internet files,
then reload the page and see how you go.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
