you are in the best hands with robbie ward when it comes to rb30's
he helped me a lot with my rb30 setup & also supplied the sump kit with adapter - great guy & cannot speak highly enough of him :)
This is what I was thinking.
The inlets, I would get aluminum pipe mandrel bent at the same angle as stockers and accept that it would use a 60-65mm inlet bellmouthed out and welded to the 3 inch shortened compressor snout.
I agree jangles. The v band idea would work well too.
+1 on both of these. . .trying to get something fabbed up for my build as well. . .I went the Precision Billet equivalents. . .and would like to see if I could keep the TT pipe and oem airbox. . .I would say V-bands are the way to go. . .
Looking forward to updates
I am being told that the GTX2860/2863/2867 all spool almost the same. I have a hard time believing this. All do use the same Turbine.
So just like comparing the old HKS 2510, 2530, 2540's. pretty much same back end, but different compressor wheel. There is quite a measurable difference in response and top end between all 3....
My GTX2860's will be here soon!!!
Sooo, my GTX2860's came in today. Just got either source some turb housings or see if -9 turbine housings fit....
A virgin block is at engine machinists getting prepped to my specs :D
  • 4 weeks later...
Well the -9's are sold....so I'm definately going GTX now!
The garrett dealer/distributor in Wetherell Park,(not naming names), were of no help in getting the turbine housings I required, when I rang them.
I got online and found CAPA performance. Emailed the guy and he had some on order for me as soon as I gave him the part number....how hard is it!!!?
Kudo's to CAPA!!!!
My housings are in the mail!!!!
hey guys!!
anyone thought of taking their -5 and uprating them to these gtx? 2860 or 2863 ?
It's been discussed somewhere. You would have to machine out the covers to accept the different wheel. Why wouldn't you just buy a set of GTX's and sell what you have?
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
