If you share that 3.5" exhaust between the 2 GTX63s it is only 1.75" diameter exhaust for each 440hp turbo!
That's a huge ask from 1.75"
That Z32 shows its doable just open up the inlet and exhaust more and if it doesn't work then I'll right them off.
But for now there my 600 wheel horsepower turbo of choice
Edited by mr skidz
Front housing machining has been done on my GTX2860's, picked them up from MTQ this morning.
I'm about to do a multi week roadtrip down to Victoria, so they won't be going in for a little while. I'm hoping maybe January. I need to sort out a few things first, like fuel system and exhaust.No point putting them in if something else is holding them back.
  • Like 3
Gorgeous wheels pete, how much power are you aiming for?
E85?
Just spin them as hard as you can too..
I've been held up by my machinist he hasn't given me my head back yet so I'm able to delay my turbo choice.
Edited by mr skidz
As above, they're -5 housings so .64 ar I believe.
And yes, e85 of course!
Power wise, that's to be determined by my work outlook. Worst case I suppose would be standard engine with arp headstuds. Id still throw a heap of boost in but may be limited
  • Like 1
Nothing wrong with the standard bottom end, as you said just wack a set of ARP2000 studs and also maybe some drop in cams and away you go!
  • Like 1
One for you pete, GTX2860's custom high mounts on a std 2.6L pulled 373 rwkw on only 17psi using stock ported comp covers and says .73 turbine housings??
Definitely different
https://instagram.com/p/77nQx7FHfn/
Edited by mr skidz
Does any body know if a -9 rear housing will work with the gtx cartridge? Wheels are the same diameter just a different trim, 76 vs 62. As i have -9's now was wondering if i just got the machining done and swaped out the cartridges.
edit: Looks like the -9 rear exducer is 34mm while the -5 is 41mm so I'm guessing no, only other question is will a gtx2860 front compressor fit on a 2859r cartridge?
Edited by fomby639
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
