  • 3 months later...
I demand an update. Has anyone wound up the boost (25+psi) on e85 with these yet?
Im very interested in the 63's on the 2.6..
Read the thread from the beginning :P
I can't believe these turbos are 4 years old....
Yea time flies.... Im talking about the guys in the last 3 or so pages that are in the process of doing the gtx thing. Havent heard anything for months..
Interesting about the 67s in the hks housings... Ive got 2530s on mine currently. Going on a stroker or 2.6?
  • Like 1
HKS 2530 upgraded to GTX67 front wheels. No other changes have been made to the car besides the front wheel upgrade.
Dyno updates coming in 2weeks.
please keep us posted keen to see how these go
What made you go 67mm front?
2.6L. Made 430rwkw on pump and 460 on toluene. This time it'll be on E85 so it should be interesting what it makes.
Specs of the setup? Cams? Headwork? Exhaust size?
  • 3 weeks later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
