Lolz at Simon, 'take your slow Gts-t and go home' hahaha that really cracked me up, how many awkw wast that T04Z GTR??, i think i dont like my GTT anymore...
430rwkw, that video it was only running about 400rwkw
It was a rocket man, why would you give that GTR up for a sideways sliding GTS-t....me no understand..
I sold my GTR for a deposit on my house. I bought my Gts-t for cheap after that and having been building it up since :cheers:
  • Replies 231
Sensible driving, unless you took off like a granny, 1st gear in a high powered gtst is useless as soon as it comes onto boost it's wheel spin and same with second. In the rain.... Omg you have absolutely no chance of getting near boost. The gtst is quick don't get me wrong, but when it comes onto boost say on the on ramp like you said from 60 or 80 you just wait to correct the steering wheel if it completely breaks traction or it's twitchy fighting for grip.
The gtr just has a feeling of immense power and torque and when you get on the go pedal hard or soft there is no worries about grip. You have to look ahead to see how far the car is ahead of you as it just picks up speed über quick.
The gtr is able to use its power on all of its range and gears without issues to be quick, the gtst is fast once you get past the looseness and wheel spin.
Yeah but it takes a massive amount of man essence to pilot that rwd GTST. A school girl could drive a GTR fast though.
I'm not denying that, that's why sometimes I would like to have a 300kw gtst cause there so much fun. The thing I'm learning about the gtr compared to the gtst but is how fast you pick up speed because there is no wheel spin, you have to be careful of how far cars are ahead of you before you bring it onto full boost.
Has anyone with a GTS25t or GTt with around 400kw tried them on MT ET street radials?? I've been in a 10s R33 and on street tyres it was definitely a joke below 4th, though seen vids of Supras in the states with mental power being relatively composed on radials more suited to the purpose
it's all in the setup...
i have had a 300rwkw gtst for around 3 years now with a fairly responsive setup, and for me it all comes down to tyres.
Usually i run Nitto NT-05's (only in a 235) and with them i can smash the firewall in any gear with no worries providing I keep it set on low boost (300rwkw). on full boost (325rwkw) it's a little beyond the possibilities of the rubber, but still very predictable.
but an R with the same power to weight and response will eat a gtst every time
But how much more power does a GTR need to compensate for the extra weight of the 4WD system.
My 300ish killer wasp T was keeping up with, and beating a few 300ish killerwasp Rs, needless to say they were not doing 8k launches, and last time I was at the drags a old VL was smashing everything with its old RWD system.
It's not as simple as "It's a GTR man"
Let's settle this at the next SAUNSW drag day, I'll race for icecreams and coffees, I'll be in my RWDFTW boat, I'll race any simular powered GTR on the day.
It's funny how people think GTR's somehow drive themselves around corners. They do bite if you get it wrong!
This... Is quite true.
While wrxs and evos can be piloted by any gumby, I've only been in one GTR on a track where the driver knew how to drive it.
Remember attessa (awd) doesn't come into effect on a GTR until the back comes loose...
So to be quick, you must get the back loose, point the front where you want to go and open the throttle... Most people back off at the point of the loose rear. Most GTRs only get there awd used on the launch for this reason...
Your in mark!
I'm I'll be running my 400ish rwkw tune though, that will even up our displacement difference ;)
quick rough maths says around 23% (assuming 1350kg gtst and 1750kg gtr)
so ~300rwkw gtst = ~370awkw gtr
You must be talking about the 35 GTR...
Must remember torque is goin to play a large role in this as well, it's not just all killerwasps
Not all the time. It's determined by steering angle, speed, RPM and throttle position. If you go back to 2nd or 3rd on the freeway and nail it for example, you will see the torque gauge rise and fall.
shit... sorry, you are correct... so assuming 1550kg for a 33
figure would be more like ~340awkw
makes a bit more sense ;)
also i'm not taking torque into account at all here... just power/weight
+1
Mine will do it even taking off mid-throttle from the lights. No chance there would be wheelspin, but it sends power up front regardless for quite a while longer than you'd think.
But then i do have a modded transfer case, wondering if that makes a difference or not as well.
+1
Mine does it too pulling away from lights. Might go to to 10kg/m for a second or two then back to zero.
I was neck and neck with an R35 GTR down the main straight of EC when I only had 320rwkw and im sure his wasnt standard.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
