  • Replies 231
I don't street race period.
I use nitro vs air.
Which when I set pressure it usually holds it for a long period of time.
Yes I double check prior runs but basically when it is tuned its done.
So I know when I drive home and go back the next weekend I still have the same psi.
Last thing is dot tires are street tires. They just don't last long as your regular dot 100+ thread wear.
The Hks hyper d coil overs are proven lethal in drag racing.
With less tuning require for fast runs.
I'm now using tanabe but if I was still into drag my car would still have hyper ds on it.
I have a reinforced Mazworx cross on it with solid diff bushings.
Helped me increase torque tho.
I use nitro vs air.
Sorry the google translate feature I'm using could not translate your language into English.
Its unfortunate I no longer have photoshop, MS Paint is hopeless.
I was going to photoshop a comeback of rednecks driving around in camo pants, but weve all seen your youtube vids :ph34r:
I think that's why they are good for drags straight out of the box though, the soft wallowing suspension aids in the rear squatting and the front lifting, whereas the Skylines with there sporty suspension is a bit to firm for hooking up.
Although the VL does handle a bit more like the Queen Mary when going around corners.
I think, LOL.
Try live axle vs IRS, and vl's weigh a lot more than 1100kg..lol, try nearly 1300kg for a basic sl, and the calais are heavier, R31's are a bit heavier again, but made better.
fastest full street trim vl is around 9.7 at 142mph atm(e85), with stock suspension to i think, knowing what turbos on it, if it had the same turbo as it
had on it before, when it ran 9.9 on 98 0ctane it will go much faster no doubt
cheers
darren
Edited by jet_r31
So u drive around the street with less tyre pressure in your rear right tyre?
Or do u just jump out and lower it when ur at the lights after pulling up next to a GTR
I think what he is saying is that at the sharp end of drag racing AWD is no advantage, it is only on street tyres and for drivers who can't drive that it helps a lot. :thumbsup:
haha drivers that cant drive, a 32 GTR can be unforgiving i assure you. Found that out first hand.
i give this thread a day before its in the wasteland
I stand corrected, their between 1250 and 1350 kg.
Those weights are for NA versions, you forget the turbo gear.. its actually between 1294 (SL)and 1383kg(calais), then on top of that you add a intercooler and piping as they never even had that standard.
cheers
darren
R35's run pretty impressive times seeing as they weigh a crapload. Found this dyno sheet of a stock R35, for anyone interested.
You do realise they have a highly advantageous transmission compared to the standard manual/ auto boxes do you? That transmission alone shaves precious tenths off.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
