This is a good thread for potential GTR owners....buy a GTR, then budget the cost of purchase for onging maintenace/upgrades/surprises. Still beats playing golf for kicks though!
Hope everything is progressing well.....very keen on updates!
Edited by nick_7g
  • 4 weeks later...
  • 1 month later...
What dumps are you running??
standard dumps
Standard Dumps???
I Cant believe you went to the trouble of changing out turbos, fabricating custom front pipes & exhuast and then left the biggest restricting factor in the system on there...
Not sure if anyone else has suggested but if they are the cast ones...they are only good as paper weights, get a set of the stainless R34 GTR Dumps at a minimum...
Watching this space!!!
Edited by krayzie32
  • 3 weeks later...
the car is now back with the tuner
with the following additions:
- OS Giken 3 Gear Set Box
- Koyo radiator
- New water pump
- Gates belt
- New seals
have also given tuner the following:
- ARP studs
- Tomei head gasket
- Tomei cam gears
head is being pulled apart to have springs/valves adjusted.
Hopefully have some good news this time next week!
Edited by usmair
I made 340rwkw @ 18psi through stock R33 GTR dumps without a problem at all.
Put on Tomei ones when i put on -5s (compared to other -5 setups using stock dumps, same spec built engines/dyno), the only difference... The exhaust note sounded different. So probably not the best $600 I'd ever spent.
thanks for yuor honesty! I actually sold my tomei dump and manifold before even using them, used R34 one and r34 ported manifold instead.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
