Hi all,
I've had my car for a few months now and there are some things which i can easily see were modified. However, I'm still not sure whether my turbo is stock or not.
It already had a manual boost controller installed and it was turned up to max boost, which boosts beyond the reaches of the stock boost gauge. I'm worried that if it's a stock turbo, the turbo can't handle the boost and will blow soon. I don't want to turn down the boost (for obvious power reasons). Are there any tell-tale signs of a stock turbo? I can't see any signs or writing on the turbo without taking it out. It seems to be a bit rusted compared to the rest of the components next to it so I'm wondering if that's normal, or some second hand or aftermarket turbo in there.
I'll put some pics up when i get a chance.
Thanks guys,
Jay-C
https://www.sau.com.au/forums/topic/388400-is-my-turbo-stock/
Put it on a dyno and find out just how much power its making and how much boost its running.
Dyno opperator will be able to tell you if its safe or not.
If its got well over 200kw and tuner says its safe you can assume that its tuned and has an upgraded turbo, if its making around the 200 mark or less then its a stock turbo and you should turn the boost back to 12 at most.
This is if you fail at identifying what it is for yourself. You really should have asked about the cars full history when you handed over your hard earned coin....
Not sure if this helps you at all, but these are pics from the original owner of my car when the old turbo was done -
BEFORE -
AFTER -
Errrr it would appear the first AFTER image is EPIC FAIL..... Sorry >_<
Just going on the pictures, you can quite clearly see that the turbine side (exhaust wheel) is much larger and looks to be steel in the after shot. Very confident that if those pictures are of the same turbo and it is on your car, you have high flow job.
Dude, i only posted them for an example for the guy that started the topic :cool: That turbo was off my R34......... Was trying to help!
Thanks for the responses. Yes, 34GTT i realise that post was for me to get a better idea of what it could look like. I'm not going to be taking the turbo out though so i'm hoping that i can tell just from the housing.
i guess if it says "nissan" on it, it's stock.
No, that isnt totally correct.
You can have the stock turbo high flowed to make more power. So your turbo may LOOK stock, but the internals are far from it.
AS mentioned the easiest way is to see if the compressor inlet has been bored out. :)
Edited by gotRICE?
Another way to tell is by the cartridge. Often hi flow jobs consist of putting a different cartridge such as a 2860 or 2871. The casting of the cartridge looks different to that of stock, If its a relatively new hi flow, the cartridge will look newer and with less rust.
I sent a stock RB20 turbo off to hypergear to get high flowed, and when I got it back the centre housing of the turbo looked quite different to before, obviously very clean, but also different, so posting a pic of that as well might help?
What sort of power did the RB20 make after you got it back from Hypergear? and was there much difference in the low to mid range response? am considering doing the same.
Mike.
coz he originally bought it already moded and has NFI?
a couple of the cars i sold were sold on rep, the new owners have NFI whats in them and if they arent in contact with me when they sell then they never will
equally so many people get their cars done at shops and dont ask questions
Mike.
Am getting it tuned very shortly, hopefully next week, but on whatever tune is running it spools up well, no power after 5000 rpm, but it's got some weird chip in the ECU that will be gone for a Nistune and should make some good power, looking like it will be great value for money, watch the RB20 upgrade thread, will be posting there after the tune, but for the money, so far recommended.
Didn't mean to hijack, carry on.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
