mods:3076 .82, apexi pfc, z32 afm, tomei intank pump, greddy plenum, bodge ebay manifold, tial 44mm gate, 3" straight thru, 52mm rad, earls oil cooler, gtr intercooler, high flow injectors, std coils, std cams, std headgasket, apexi POD.
fuel: ultimate
power: 300 on 19psi.
oil: royal purple 10w 40.
useage: drift, hard thrashing. No daily duties as i cant drive that through traffic at 8,100rpm as i like it.
lifespan: 4 years.
failure: countless sets of tyres.
comments: if the tunes right it wont fail... for a long time..
Mods: 1995 S2 Rb25, Kando T67-25g. check the specs and sheet here http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__view__findpost__p__6010134
Fuel: E-flex e85
Power: 340ish on 18psi.
Oil: Penrite SIN 10-70
Useage: Looking pretty in the Garage mostly, needs to see the track but don't have the time right now.
Lifespan: Ran stock turbo for 160000ks had the T67 on for about 5000ks/1 year now.
Failure: battery went flat once :rofl2:, valve springs apparently show weakness after sustained revs but its not something I have noticed on the street.
Comments: Would like to upgrade a few things to reach the limit of the turbo, might just wait and see how Simon goes with the cams first...
awesome, can u post up a dyno sheet please
Also has a JJR ex cam gear, forgot to mention.
made 300/301 when it was at cooler themps, this was after a whole days tuning. bleeding that it shows .1 off
Edited by LTHLRB
Fuel: E-flex e85
and i thought my 10w60 was thick!
mods: Subaru 500cc, fmic, exh, clutch, splitfires, Link G4 with boost control, Nismo fuel pump/thermostat
fuel: BPU
power: 272 @ 1.2 bar
oil: Penrite syn 5w60
useage: Weekend/Monthly car
lifespan: @ 180-190kw for 5+ years, @ 272 kw for 2 weeks.
failure: Tough wood!
comments: Need more power!! RB30det or sell up for a 32R?
fuel: BPU
What turbo??
Thought this was the 300kw club?:blink:
Was thinking the same thing.
No one cares if it made it on a cold day or just on one run. Im assuming the OP wanted people that have a SOLID 300kw+ to post.
Should of made it 310kw to flush out all the 3076 on 98 dweebs.
lol... honestly i'm happy with ~290... thread is aimed at getting a "survey" of how long they lasted...
so far we have had 2 failures, mine and simons, both that made the power for more than 2 years
Yeah its a great thread highlighting the strength of the RB25. I think its great. Its also a bit of a laugh to see how long they last being lent on as hard as alot of people do.
Its also a good guide along with the RB25 Upgrades thread for those wanting to hit a solid 300kw, which yours has done solidly, and thats sweet.
The people guessing and estimating 300Kw and those who got one lucky dyno run at 300 but dont really have that much power should have their posts deleted to keep the thread on track thats all.
I should get Deanc to post in here making 350 on 98 for 3 years so far haha.
Hi all
Here is mine,
mods:fmic, nistune,highmount gtx3076r Tial .82 housing, tial mvr gate, greddy plenum, 1000cc injectors +rail & reg +more
fuel: e-flex
power: 396kw was most, but have a sheet for 394kw
oil: motul turbolite
useage: about 100km sofar,(needs more fuel supply, and more $)
lifespan: fingers crossed
failure:
comments: dyna pack dyno... start hating
woah, 394rwkw from a 3076.... I didnt think they could possibly hit that much....
what other mods to produce that???
Haven't got a mod list handy, but not a lot more.
Car is on cover of next HPI Mag, plenty of info in there.
Plan is to work on the lag now, turbine housing to be dropped down, + cams etc
And no wonder, look at that engine bay! I take my hat off to you sir, that goes straight to the top of my favourite 180's list. Will be buying the HPI mag for sure thumbsup.gif
Hi all
Here is mine,
fuel: e-flex
failure:
Almost a direct overlay of my T67 set up on the same type on dyno with the same correction... Actually uncanny!
Which begs the question, how much boost?
  • Like 1
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
