mods:3076 .82, apexi pfc, z32 afm, tomei intank pump, greddy plenum, bodge ebay manifold, tial 44mm gate, 3" straight thru, 52mm rad, earls oil cooler, gtr intercooler, high flow injectors, std coils, std cams, std headgasket, apexi POD.
fuel: ultimate
power: 300 on 19psi.
oil: royal purple 10w 40.
useage: drift, hard thrashing. No daily duties as i cant drive that through traffic at 8,100rpm as i like it.
lifespan: 4 years.
failure: countless sets of tyres.
comments: if the tunes right it wont fail... for a long time..
Mods: 1995 S2 Rb25, Kando T67-25g. check the specs and sheet here http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__view__findpost__p__6010134
Fuel: E-flex e85
Power: 340ish on 18psi.
Oil: Penrite SIN 10-70
Useage: Looking pretty in the Garage mostly, needs to see the track but don't have the time right now.
Lifespan: Ran stock turbo for 160000ks had the T67 on for about 5000ks/1 year now.
Failure: battery went flat once :rofl2:, valve springs apparently show weakness after sustained revs but its not something I have noticed on the street.
Comments: Would like to upgrade a few things to reach the limit of the turbo, might just wait and see how Simon goes with the cams first...
awesome, can u post up a dyno sheet please
Also has a JJR ex cam gear, forgot to mention.
made 300/301 when it was at cooler themps, this was after a whole days tuning. bleeding that it shows .1 off
Edited by LTHLRB
Fuel: E-flex e85
and i thought my 10w60 was thick!
mods: Subaru 500cc, fmic, exh, clutch, splitfires, Link G4 with boost control, Nismo fuel pump/thermostat
fuel: BPU
power: 272 @ 1.2 bar
oil: Penrite syn 5w60
useage: Weekend/Monthly car
lifespan: @ 180-190kw for 5+ years, @ 272 kw for 2 weeks.
failure: Tough wood!
comments: Need more power!! RB30det or sell up for a 32R?
fuel: BPU
What turbo??
Thought this was the 300kw club?:blink:
Was thinking the same thing.
No one cares if it made it on a cold day or just on one run. Im assuming the OP wanted people that have a SOLID 300kw+ to post.
Should of made it 310kw to flush out all the 3076 on 98 dweebs.
lol... honestly i'm happy with ~290... thread is aimed at getting a "survey" of how long they lasted...
so far we have had 2 failures, mine and simons, both that made the power for more than 2 years
Yeah its a great thread highlighting the strength of the RB25. I think its great. Its also a bit of a laugh to see how long they last being lent on as hard as alot of people do.
Its also a good guide along with the RB25 Upgrades thread for those wanting to hit a solid 300kw, which yours has done solidly, and thats sweet.
The people guessing and estimating 300Kw and those who got one lucky dyno run at 300 but dont really have that much power should have their posts deleted to keep the thread on track thats all.
I should get Deanc to post in here making 350 on 98 for 3 years so far haha.
Hi all
Here is mine,
mods:fmic, nistune,highmount gtx3076r Tial .82 housing, tial mvr gate, greddy plenum, 1000cc injectors +rail & reg +more
fuel: e-flex
power: 396kw was most, but have a sheet for 394kw
oil: motul turbolite
useage: about 100km sofar,(needs more fuel supply, and more $)
lifespan: fingers crossed
failure:
comments: dyna pack dyno... start hating
woah, 394rwkw from a 3076.... I didnt think they could possibly hit that much....
what other mods to produce that???
Haven't got a mod list handy, but not a lot more.
Car is on cover of next HPI Mag, plenty of info in there.
Plan is to work on the lag now, turbine housing to be dropped down, + cams etc
And no wonder, look at that engine bay! I take my hat off to you sir, that goes straight to the top of my favourite 180's list. Will be buying the HPI mag for sure thumbsup.gif
Hi all
Here is mine,
fuel: e-flex
failure:
Almost a direct overlay of my T67 set up on the same type on dyno with the same correction... Actually uncanny!
Which begs the question, how much boost?
  • Like 1
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
