Hey can I join the club?
Just upgraded to Deatschwerks 950cc injectors and retuned for E85
Very happy with the results!
From 274rwkw (98) to 314rwkw (E85) with a massive increase in mid-range power
Pushing 500HP and very responsive - full boost by 3250rpm
This is an overlay of the E85 and 98PULP dyno results on exactly the same set up (100% unopened) apart from the injectors & tune.
First time posting and I'm not sure If this is the best place to post..
I've got a RB25de neo 6 R34
With a
AIResearch T60 T04E turbo
Externally gated on a slide industries manifold
700cc Bosch injectors
Apexi power FC
Bosch 044
Apexi FMIC
3inch stainless turbo back exhaust
Cometic head gasket
Arp studs
FFP
How much would I expect to see out of it?
How much boost could I push?
Could I run 300kw with that setup as a daily?
rb25 neo
t67 10cm
880cc sards
sard reg
greddy rail
tomei type b
greddy intake
npc cushioned clutch
oil accumulator
oil cooler
3" straight trough
stock head gasket
98 bp
340 @17 psi graph in dyno thread
Unopened rb25 neo
Holset hx35 turbo
Chinese manifold
Custom intake manifold
Denso -850cc injectors
Turbonetics 44mm gate
3 inch exhaust
Spitfire coils
Sard fpr
Both 044 an 040
Z32 afm
Power fc
Car makes 304kw atw on 16 pound an 279Kw atw on only 12 pound
  • 8 months later...
1998 Nissan Skyline R33 Gts2.5t
40th Anniversary Edition.
Mechanical Nismo Selective 1.5 L.S.D. diff
Nismo G Max II clutch
Bilstein shocks with King springs
Whiteline adjustable swaybars front and rear
Whiteline adjustable nolethene bushes for camber/castor/toe at all four wheels
HKS triple layer dry pod filter
Z32 Mass Air Flow Meter
Sard adjustable fuel pressure regulator
555 Nismo injectors
Splitfire coils
Blitz 700x600x70 fmic (anodised blue)
HKS IV electronic vacuum controller (boost controller)
Blitz turbo timer
Trust alloy oil cooler with stainless steel braided lines
Apexi alloy radiator
Cusco high pressure radiator cap
D1 oil catch can
Master cylinder brake brace stop bracket
Project mU front discs [brakes]
Braided stainless steel brake hoses [full kit]
90mm exhaust with HKS Hiper 120mm s/s muffler
Cusco front tower strut bar
Snow Performance Stage 3 Boost Cooler water/meth injection kit
Garrett GT3076 WG turbo with 100mm port shrouded comp cover
HKS 40mm external wastegate [18psi spring rate]
HKS cast low mount manifold extrude honed and flowed
Tomei adjustable exhaust cam pulley
Tomei Poncams 256 degrees/8.5mm lift
Apexi Power Full Computer with Hand Controller
Making 302, so just snuck in, chart is in Dyno thread.
Apologies for the crappy format, I cut and pasted from a word file and CBF fixing it.
oh hai... forgot I made it into this club a while ago...
343kW on 1.65bar of boost (Mainline Dyno) on E85
Stock Motor, Stock Cams, Stock Head, Stock Manifold (Intake & Exhaust)
Hypergear SS2 (internal gate welded shut & 3" v-band exhaust)
Scotty Custom 45mm External Gate Mod on Turbo Housing
Turbosmart 45mm Hypergate External Wastegate
875cc Siemen DEKA IV Top Feed Injectors
Sard (fake I think) Fuel Pressure Regulator
Walbro 450L Fuel Pump
Splitfire Coilpacks
Hybrid FMIC
Plazmaman Swept Back Cooler Piping
Typical 3" Exhaust System (1x Resonator, 1x Mid Muffler, 1x Fujitsubo Rear Oval Muffler) & Screamer Pipe :)
Adaptronic ECU, self tuned
  • 3 weeks later...
Look at where the power curve is going. Straight over 400rwhp. Dyno cuts out. They are getting me back for a power run to have a full graph. This will give you an idea.
HAHA that predictor is awesome, it's making on average a few hp more up to when the "dyno cuts out" but somehow it's going to gain 30hp? 405rwhp would be more on the money
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
