GTX35 is an awesome turbo but it only belongs on an RB25 with 2bar of boost
^^ This, otherwise you went too large on your turbo.
It's capable of 430kw at least, hanging off a factory manifold with a gutfull of ethanol...
  • Like 1
Yes there is either a problem with the wastegate or the rear houseing is not a good match for the turbo. Not worried about it for now bit over it gor now. Was advised by so called people on here to go with .82 rear. Wishing I stuck to my guns and put a .63 on it. Leaving it like this till I bolt my forged 3lt bottom end together. I agreed it should be making more power. Will be changing tuners thats for sure.
^^^ Told him to stick with the GTX3071R but didn't listen!
Picked up the GTX35R for a good price so couldn't turn it down.
Told him not to go .63 he DID listen but still insists on using the .63 even after the entire internets has agreed with me lol.
The 3071 woulda smacked that all over ball park mate and it'd be on song 2000+rpm earlier! :(
Lead a horse to water......
Only grabbed the 35 as im building a 30 bottom end. Otherwise yes would of stayed with the 3071. The 35r should be able to make full boost by 45 to 4700rpm. That I could live with on a 25 bottom end. This is just ridiculous at 6000rpm. Something is not right.Currently doing investigation to find out why. First thing I'm looking at is the wastegate then I will be having the turbo inspected to see if any problems with it. There is no gas leaks I can see or hear.
Thats a low 9 sec turbo on e85 in a lc with a 3.0bottom and auto
with a bigger housing.
dont blame the tuner..its highly obvious that your problems are elsewhere... The tuners job is to tune what comes in..its the person who put it togethers problem.
If its auto then id take a gtx3582 over a gtx3071 anyday
people have to remember it aint in a manual r33/34...
massive difference..
cheers
darren
Edited by jet_r31
  • Like 1
Found the problem. Roll pin in v band had partly fallen out. This alooud an exhaust leak in an area where it was unable to find. Bugger. Now when I fix it I will need a retune. Just hoing to fit a screamer pipe instead of plumb back as I think this might be part of the problem too putting extra presure on the clamp.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
