That was on E85. Neo engine's pretty good, didn't have issues taking boost, and I didn't experience valve floating issues either. The external gate is welded to factory exhaust manifold, search the index page on my thread, there are few pages explaining how.
I run 98ron as the car can sit for months at a time. I dnt mind e85 but will wait until the new engine is run in.
You have the fuels all backwards, it's the 98 I wouldn't leave for months as it goes stale and detonates. Ethanol has no problem with sitting for a few months in a sealed container or tank.
E85 draws in moisture from the air. Thats what stuffs everything.
Hence why I said sealed container. How much water do you think it will suck in through a wall of steel or plastic?
I have had none of the issues you have described, actually I have had no issues at all in 5+ years running e85.
  • Like 2
I had some ethanol stored in a plastic container for about 6months , opened several times to mix with some 98 and I found that it had turnt cloudy, I'm guessing it must of absorbed moisture from the air or maybe there was moisture in the 98 it was mixed with?
Edited by AngryRB
Go back to p1
People said that about this club
And their predictions are becoming truer and truer with each 100kw.
Reminds me of a saying - There's old motorcyclists and there's bold motorcyclists, but there are no old bold motorcyclists!!!
Also found this on another website:
Coulson, Richardson & Sinnott report that:
  • aluminium, aluminium bronze, brass, copper, gunmetal and bronze, high Si iron, nickel, nickle-copper alloys, platinum, silver, stainless steel (18/8, molybedenum & austenitic ferric), titanium, tantalum, and zirconium
  • nylon 66 fibre & plastics, PCTFE, PTFE, polypropylene, and furane resin
  • hard rubber, neophrene, nitrile rubber, chlorosulphinated polyethylene, and silicone rubbers
  • concrete, glass, graphite, porcelain and stoneware, and vitreous enamel
are corrosion resistant to alcohols, beer & water up to 100C.
  • lead, mild steel (BSS 15), cast iron, and tin
  • acrylic sheet (eg perspex), acrylonitrile butadiene styrene resins, rigid unplasticised PVC, plasticised PVC, polyethylene (low & high density), polystyrene, melamine resins, epoxy resin, phenol formaldehyde resins, polyester resins
  • butyl rubber & halo-butyl rubber, ethylene propylene rubber, soft natural rubber, and polyethylene rubber
  • wood
So I'm drinking my beer out of glasses...........
Ive had e85 in those plastic jerrys for 6months and had no issues used it in the car after that, have also left e85 in metal jerrys outside in the rain in winter for few months again used the fuel and no problems.
  • Like 1
Ethanol is highly hygroscopic, yet all that means is it will absorb water out of the air until it's so saturated you get phase separation. However, if air can't get to it then it can't get water out of the air. Depending on tank breathers and such will determine if fresh air can get into a fuel tank Easyer enough to cause an issue. On most cars not so much. In sealed containers not at all.Also some company's have additives in fuels to help with it. Basically unless you fuel system has leaks ( that's a big problem) then you shouldn't really have issues except for really long term. I've had some issues with a tank that was about 1/4 full and sat for 6 months yet the fuel cap also wasn't on properly.
Oil contamination can be an issue though. Expecially with how open to air some motor can cases are. Yet if you use the right oil for it. Or change it out more often again not an issue.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
