This hasn't been updated lately, but as it stands at the moment the fastest is a 260rs with a 12.3 then Darren spencer's rs with 13.01 then my 260 with a 13.2
The fastest so far in here is 11.3...hasn't be updated for a long time
According to my Google search, a S2 C34 with RB25DET came with 173Kw at the engine. 12 years later it has 155awKw - only 18Kw loss thru the drivetrain. Is that possible, even with a manual transmission? I suspect some Walt Disney optimism at play, lol.
Nice car tho. I like them in yellow.
S2 c34 had the rb25detNEO, so 206kw from the factory.
Most stock stags lay down around the 135-150kw depending on manual/auto awkw/rwkw.
1996 s1 with a manual and a neo engine conversion.nistune, 3076r, poncams etc etc e85. just need to sort out the old girl so she holds boost, new waste spring and clean up tune under the curve and should be even better but already she is fun shopping wagon.
Sydney Motor Sport Park - South Circuit.
1:14.77 - (34*C with stock brakes and hawk ceramic pads - also overheating) lol
was good fun but took it easy on the brakes could only do 2 lap sprints before i needed to do a cool down lap as i could smell the brakes HAHA
and definately need some semi slicks rather than the federal 595's!!!
then i'd feel much more confident in the car but i learnt alot and the car handled beautifully otherwise!!!
  • 3 weeks later...
this thread needs a update
1998 Stagea 260RS
407.4 HP (303KW) @ 20PSI on caltex 98 safe daily driver tune
Congrats excellent job but she is fun to drive .
And yes this thread really needs an update lol...
Thanks mate, it definately starts to come alive with 300kw! The 4wd is starting to work a bit harder now.
When is ur's going back in for a touch up?
When i get off my butt . Bit busy with our new baby. Got to change waste gate spring and sort the boost controler out get it to hold stable then turn it up to around 20 ish psi. Also got water/meth injection to hook up basicially to lowr exhaust temps should be interesting to see what she make. Dont think my gear box is going to like it hmmm
1998 Stagea 260RS
We really really need some "more" m35s to make some power then this thread might get updated lol....... oh no did i just say that
OK, updated doc sent to mods for updating the 1st page.
some of the figures (power) weren't high enough to bump the next person off.
Remember - keep posting in here, so its easy to update when I CBF.
  • 2 years later...
  • 3 weeks later...
Well finally got round to re tuning stagea after all these years ( to busy working on customers cars ) ( and the shops s15)
Old tune 338rwkw 311awkw at 19 psi
New tune 360-370rwkw 340.1 awkw
Still the same standard neo bottom end and small 3076.63 all standard manifolds and return flow cooler , video is of Chris and my self doing a 3rd gear pull 335 awkw 4th gear is 340 awkw @27psi
  • Like 3
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
